Bookmark
Subscribe
1322
Check Running Config/Startup Config of Second Supervisor
Evlaa2021
Is there anyway to check the current configuration loaded onto the inactive / standby supervisor on a Nexus 7K. We have an issue saving the configuration on the active SUP. So we are looking to failover but i don't wan't to do this until i know the running config are the same across both modules. What's the best way to go about this?
as far as I recall, you can only check the redundancy status, which should look like below. The internal state 'HA Standby' means that both supervisors are synchronized...
switch# show system redundancy status
Redundancy mode
administrative: HA
operational: HA
This supervisor (sup-1)
Redundancy state: Active
Supervisor state: Active
Internal state: Active with HA standby
Other supervisor (sup-2)
Redundancy state: Standby
Supervisor state: HA standby
Internal state: HA standby
marce1000
       >...We have an issue saving the configuration on the active SUP.
  - What is the issue ?
 M.
