CISCO 1117 dialer
ronsametcohen
Hello .
I down why , but I dont get a ip by the dialer interface .
help please
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   10.10.10.1      YES NVRAM  up                    up
GigabitEthernet0/1/0   unassigned      YES unset  up                    up
GigabitEthernet0/1/1   unassigned      YES unset  administratively down down
GigabitEthernet0/1/2   unassigned      YES unset  administratively down down
GigabitEthernet0/1/3   unassigned      YES unset  down                  down
Cellular0/2/0          192.168.124.3   YES IPCP   up                    up
Cellular0/2/1          unassigned      YES NVRAM  administratively down down
ATM0/3/0               unassigned      YES NVRAM  up                    up
Ethernet0/3/0          unassigned      YES NVRAM  down                  down
Dialer1                unassigned      YES NVRAM  up                    up
Controller VDSL 0/3/0 is UP
Daemon Status:          UP
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0xB206
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:     C1117-4P 16.9.2
Serial Number Far:
Modem Version Near:     16.9.2
Modem Version Far:      0xb206
Modem Status:           TC Sync (Showtime!)
DSL Config Mode:        AUTO
Trained Mode:           G.992.5 (ADSL2+) Annex A
TC Mode:                ATM
Selftest Result:        0x00
DELT configuration:     disabled
DELT state:             not running
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Modem FW  Version:      4.14L.04
Modem PHY Version:      A2pv6F039t.d26d
Modem PHY Source:       System
Line 0:
Trellis:                 ON                      ON
SRA:                     enabled                 enabled
SRA count:               0                       0
Bit swap:                enabled                 enabled
Bit swap count:          15154                   0
Line Attenuation:        24.0 dB                 11.3 dB
Signal Attenuation:      23.0 dB                 11.2 dB
Noise Margin:             9.1 dB                11.0 dB
Attainable Rate:        22436 kbits/s            1148 kbits/s
Actual Power:           20.0 dBm                10.4 dBm
Total FECC:             3964806                  2
Total ES:               513                      2
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              480                      480
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             NA           18938            NA               918
SRA Previous Speed:       NA               0            NA                 0
Previous Speed:           NA           18941            NA               918
Total Cells:              NA        76390442            NA        1878229804
User Cells:               NA               1            NA                 0
Reed-Solomon EC:          NA         1751049            NA                 0
CRC Errors:               NA             595            NA                 2
Header Errors:            NA             126            NA                 0
Interleave (ms):          NA            7.87            NA              0.23
Actual INP:               NA            2.22            NA              0.03
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
interface ATM0/3/0
 no ip address
 atm oversubscribe factor 2
 no atm enable-ilmi-trap
 pvc 8/48
  pppoe-client dial-pool-number 2
interface Ethernet0/3/0
 no ip address
 no negotiation auto
interface Dialer1
 ip address negotiated
 encapsulation ppp
 dialer pool 2
 ppp mtu adaptive
 ppp pap sent-username xxxx@xxx password 0 xxxxxx
balaji.bandi
Can you post the full configuration and let us know the ISP provider information?
BB
as far as I recall, if you use PPPoEoA, you need something like this:
interface ATM0/3/0
no ip address
pvc 8/48
--> encapsulation aal5mux pppoe-client
If you use PPPoA, you need this:
interface ATM0/3/0
no ip address
pvc 8/48
--> encapsulation aal5mux ppp dialer
--> dialer pool-member 2
Need encapuslation aal5, trt this and share last status
