01-03-2021 06:46 AM
Hello .
I down why , but I dont get a ip by the dialer interface .
help please
Interface IP-Address OK? Method Status Protocol GigabitEthernet0/0/0 10.10.10.1 YES NVRAM up up GigabitEthernet0/1/0 unassigned YES unset up up GigabitEthernet0/1/1 unassigned YES unset administratively down down GigabitEthernet0/1/2 unassigned YES unset administratively down down GigabitEthernet0/1/3 unassigned YES unset down down Cellular0/2/0 192.168.124.3 YES IPCP up up Cellular0/2/1 unassigned YES NVRAM administratively down down ATM0/3/0 unassigned YES NVRAM up up Ethernet0/3/0 unassigned YES NVRAM down down Dialer1 unassigned YES NVRAM up up
Controller VDSL 0/3/0 is UP
Daemon Status: UP
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'IFTN'
Chip Vendor Specific: 0x0000 0xB206
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: C1117-4P 16.9.2
Serial Number Far:
Modem Version Near: 16.9.2
Modem Version Far: 0xb206
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.5 (ADSL2+) Annex A
TC Mode: ATM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Modem FW Version: 4.14L.04
Modem PHY Version: A2pv6F039t.d26d
Modem PHY Source: System
Line 0:
Trellis: ON ON
SRA: enabled enabled
SRA count: 0 0
Bit swap: enabled enabled
Bit swap count: 15154 0
Line Attenuation: 24.0 dB 11.3 dB
Signal Attenuation: 23.0 dB 11.2 dB
Noise Margin: 9.1 dB 11.0 dB
Attainable Rate: 22436 kbits/s 1148 kbits/s
Actual Power: 20.0 dBm 10.4 dBm
Total FECC: 3964806 2
Total ES: 513 2
Total SES: 0 0
Total LOSS: 0 0
Total UAS: 480 480
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): NA 18938 NA 918
SRA Previous Speed: NA 0 NA 0
Previous Speed: NA 18941 NA 918
Total Cells: NA 76390442 NA 1878229804
User Cells: NA 1 NA 0
Reed-Solomon EC: NA 1751049 NA 0
CRC Errors: NA 595 NA 2
Header Errors: NA 126 NA 0
Interleave (ms): NA 7.87 NA 0.23
Actual INP: NA 2.22 NA 0.03
Training Log : Stopped
Training Log Filename : flash:vdsllog.bininterface ATM0/3/0 no ip address atm oversubscribe factor 2 no atm enable-ilmi-trap pvc 8/48 pppoe-client dial-pool-number 2 ! ! interface Ethernet0/3/0 no ip address no negotiation auto !
interface Dialer1 ip address negotiated encapsulation ppp dialer pool 2 ppp mtu adaptive ppp pap sent-username xxxx@xxx password 0 xxxxxx
01-03-2021 07:42 AM
Can you post the full configuration and let us know the ISP provider information?
01-03-2021 01:17 PM - edited 01-03-2021 01:21 PM
as far as I recall, if you use PPPoEoA, you need something like this:
interface ATM0/3/0
no ip address
pvc 8/48
--> encapsulation aal5mux pppoe-client
If you use PPPoA, you need this:
interface ATM0/3/0
no ip address
pvc 8/48
--> encapsulation aal5mux ppp dialer
--> dialer pool-member 2
01-03-2021 06:34 PM
Need encapuslation aal5, trt this and share last status
