09-07-2005 11:39 PM
HI,
My router C3660 rebooting itself a lot of times and it's give me the following error, so please could any one help about the cause of this error
I think it's Flash problem or damged image is that right.
$$ show ver
monitor: command "show" not found
$$ reset
System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C3660 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0xcc78d4
Self decompressing the image : ##########
Error : Uncompression of the image failed.
invalid compressed data--format violated
Error : zip decompress failed
*** System received a Software forced crash ***
signal= 0x17, code= 0x7, context= 0x80020b00
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
Error : compressed image checksum is incorrect 0x7B39289E
Expected a checksum of 0x7B397B59
signal= 0x17, code= 0x5, context= 0x80020b00
PCMCIA Slot1: No Card Present
Self decompressing the image : ###########
09-08-2005 04:15 AM
Looks like the image you have loaded is corrupt
You will probably have to transfer it again:
