Cisco 3845 SNMP
ciscoben2009
Hello All
when using SNMP on our cisco 3845 the traffic logs are set to refresh every 1 second but the data seems to come in 5 sec burst
so does not some a real time status of the interface throughput
any ideas?
thanks
Ben
Gaganjeet Chug
Level 4
Level 4
Are you trying to say when you poll the device , the response time is slow from the device ?
its seem like it is not polling it correctly for example
on a 2600 router which is set to poll every second you see the interface throughput at 100mb/sec
but on the 3845 it is set to poll every second but will show no throughput at all then after a few seconds shows a burst of 600mb/sec
hope this helps
