Cisco ACE Monitoring
pizpowergtc
Am receiving the below oid and I cannot translate it all..
1.3.6.1.4.1.9.9.254.0.2
This is what I can trasnlate till now:
ciscoMgmt.254.0.2
Cannot find any mib for this
David
Marvin Rhoads
It's part of the SLB (Server Load Balancing) MIB. I don't see the .2 object ID but .1 is documented here:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.dolocal=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.254.0.1#oidContent
It apears to be related to the FT (Fault Tolerance) state of the ACE:
ObjectcslbxFtStateChange
OID1.3.6.1.4.1.9.9.254.0.1
Statuscurrent
MIBCISCO-SLB-EXT-MIB ;   -   View Supporting Images this link will generate a new window
Trap ComponentscslbxFtState
Description"The notification generated when the Fault Tolerance
process changes to a new state. The value of
cslbxFtState indicates the new state."
yes
could it be software? or?
Assuming that logging is enabled on your ACE, I would check the ACE local log to correlate the SNMP trap with a log event.
