CISCO ASR-9901 Power Input, output current threshold value
andresw
Hi Everyone,
I have an issue with SolarWinds sensor device Cisco ASR-9901 Power Supply Input and Output current value, can anyone tell me about the Cisco ASR-9901 Power Supply Input and Output Current (A) threshold.
Here is the capture Power Supply status and SolarWinds Capture.
Thank you.
marce1000
 - Usually can be ignored in  network management software  if OK reported with manual commands on  the device , can be due to bugs in SNMP , use advisory software version on the ASR for that : https://software.cisco.com/download/home/286322162/type/280805694/release/7.3.2  , you can also connect to  the device (SSH) with https://cway.cisco.com/cli  . at the top left press or run 'System Diagnostics'
 M.
marce1000
 M.
Thank you @marce1000 for your advice, I was running 'System Diagnostics' with health result
