VSS ISSUE WITH Cisco C6840-X-LE-40G
Monuc Admins
core-utex2-1(config)#int port-channel 20
core-utex2-1(config-if)#sw
core-utex2-1(config-if)#switchp
core-utex2-1(config-if)#switchport
core-utex2-1(config-if)#switchport m
core-utex2-1(config-if)#switchport mode t
core-utex2-1(config-if)#switchport mode trunk
core-utex2-1(config-if)#switch v
core-utex2-1(config-if)#switch virtual l
core-utex2-1(config-if)#switch virtual link 1
WARNING: Interface Port-channel placed in restricted config mode. All extraneous configs removed!
core-utex2-1(config-if)#no shut
core-utex2-1(config)# int ran te1/1 - 2
core-utex2-1(config-if)#channel-group 20 mode on
Command rejected (Port-channel20, Te1/1): Either port is L2 and port-channel is L3, or vice-versa
% Range command terminated because it failed on TenGigabitEthernet1/1
balaji.bandi
core-utex2-1(config)# switchport mode trunk
try below document :
https://community.cisco.com/t5/networking-documents/virtual-switching-system-vss-configuration-for-cisco-4500-series/ta-p/3147865
BB
 Verify Te1/1 as per the logs: "Either port is L2 and port-channel is L3, or vice-versa"
We know that the Port-channel is L2 as per the commands you used "switchport" The other possibility is one of this port to be in L3.
You can do :
int range  Te1/1 - 2
switchport
looking at the exact error message, it complains that Te1/1 is layer 3. Try the below:
core-utex2-1(config)# interface range te1/1 - 2
core-utex2-1(config-if-range)#switchport
core-utex2-1(config-if-range)#channel-group 20 mode on
