Hey
I wander if anybody can shed some light on a BBSM issue.
In a wireless environment, Is it possible to configure multiple pagesets (and hence splash pages) for users associating to a single, common access point ??
Documentation seems to indicate that this is controlled on a per physical-port basis; in which case all users associating to a single access point will be presented with the same splash page.
I guess ideally i need to map a particular pageset to a VLAN or SSID as opposed to the trunk switchport that connects the access point.
Many thanks
Abdul
