Cisco Collector installation.
WaterIT
Hi I'm currently looking into Cisco collector installation.  My question is can the collector be installed on Window OS machine ?
luis_cordova
Hi @WaterIT  ,
Cisco Collector can be downloaded as ISO or as OVA, so you can mount the image in a virtual machine environment, such VMware.
I leave you a couple of links that may be useful:
https://www.cisco.com/c/dam/en/us/support/docs/services/sntc/ISO-App-Note.pdf
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Quick-Start-Guide.pdf
luis_cordova
Hi @WaterIT  ,
Does it have it be a virtual machine. Can it be installed on a physical desktop ?
