06-28-2005 08:57 AM
Is there a way in Configuration Managment to tell if device configs don't follow a standard template?
Solved! Go to Solution.
06-28-2005 10:25 AM
06-28-2005 10:25 AM
No
06-28-2005 11:20 AM
In RME 4.0 there is a baseline that you can set up and then use the baseline comparison feature to do this.
