Cisco Firepower 2130 - no console access
DSterling
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?
-Software version: 7.0.5-72
-Configured with primary and secondary
-Base license
-Not using FMC
Can someone tell me how to get console access?
Thank you,
Dave
2 Accepted Solutions
DSterling
I did reboot the FP primary and it became the secondary, I can access it now, but can't access the primary, I'm going to try to reboot the other FP that is now the primary, but may need to wait to get the OK to reboot it.
DSterling
Rebooted the other device and then had console access to that device also.  Below is the message I was getting:
Device-FW login: myaccount
Password:
Last login: Tue Apr 23 13:46:19 UTC 2024 on ttyS0
Successful Login attempts for user 'myaccount' : 2
Cisco Firepower Extensible Operating System (FX-OS) v2.10.1 (buidl 1400)
Cisco Firepower 2130 Threat defense v7.0.5 (build 72)
This account is currently not available.
Device-FW login:
7 Replies 7
hard to tell what is going wrong. Are you following this cabling guide ?
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp2100/firepower-2100-gsg/ftd-fmc.html#id_97497
DSterling
I have another FP device that I can console too. It's basic console access.
Odd. I don't want to state the obvious, but what if you reboot the FP, with the console port connected, is there any output at all ?
It console'
Did you get any error ?
Did you check cable ?
MHM
Does it show you a black screen or does it return an error stating that the console connection can't be established?
DSterling
DSterling
Password:
Device-FW login:
