question on OEMs
Tania S
 how to get Original Equipment Manufacturers (OEMs)
Ruben Cocheno
@Tania S
Talk to your Cisco Account Manager
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Leo Laohoo
@Tania S hi, contact the authorized reseller or partner for product
Good luck
KB
Ruben Cocheno
@Tania S
Joseph W. Doherty
You contact them, the OEM.
For example, if your interest is in a Cisco branded device, contact Cisco.
If your interest is in a non-Cisco component, used in a Cisco device, contact the component manufacturer.  However, on the last, first it might not be easy to identify the OEM for a non-Cisco component, within a Cisco device.  Second, often such components are manufactured strictly for a company like Cisco and/or even if not, the component manufacturer might be under contract with a company like Cisco that they cannot discuss that component being used by Cisco.
