02-14-2021 11:29 PM - edited 02-15-2021 01:14 AM
Hi everyone!
I stuck at point, can anyone explain me how to configure Cisco FMC to automatically switch to second Internet channel, when main is down.
I have this config
route Outside_KTC 0.0.0.0 0.0.0.0 188.127.36.49 5 track 3
route Outside 0.0.0.0 0.0.0.0 88.204.132.81 10
route Outside_KTC 8.8.8.8 255.255.255.255 188.127.36.49 1
sla monitor 1
type echo protocol ipIcmpEcho 8.8.8.8 interface Outside_KTC
num-packets 3
timeout 2000
threshold 2000
frequency 5
sla monitor schedule 1 life forever start-time now
Track 3
Response Time Reporter 1 reachability
Reachability is Up
342 changes, last change 15:00:07
Latest operation return code: OK
Latest RTT (millisecs) 70
Tracked by:
STATIC-IP-ROUTING 0
NAT:
Manual NAT Policies (Section 3)
1 (inside) to (Outside_KTC) source dynamic NAT_networks interface destination static any_IPv4 any
translate_hits = 15371055, untranslate_hits = 22239611
2 (inside) to (Outside) source dynamic NAT_networks interface description KT Channel
translate_hits = 0, untranslate_hits = 0
So, it looks like everything have to work fine, at least for me. I emulated 1st internet channel (Outside_KTC) down state, SLA went in down state and default route changes its direction, but Internet doesn't work over 2nd channel (Outside) until I disable NAT rule for 1st channel. Have any idea how configure it to work automatically? How to force NAT perform ip routing table lookup?
Solved! Go to Solution.
02-15-2021 03:08 AM
FMC is generally a Management platform - Dual Gateway handles by Edge devices - like FTD or Your Internet Edge Routers Failover mechanism.
if you looking to deploy this on FTD watch the below video :
https://www.youtube.com/watch?v=MKcSBTJ55e8
https://integratingit.wordpress.com/2020/08/14/ftd-dual-isp-failover/
02-15-2021 03:07 AM
FMC is "just" central management this will not switch between internet connections
my suggestion is to also add a "track" to the NAT statement, so the firewall will use the other NAT plus outbound route
02-15-2021 03:16 AM
It's obvious, but configuration to deploy on devices performs in the FMC.
Have any idea how to add track to NAT rule in FMC? Can't see this option.
02-15-2021 03:08 AM
02-15-2021 08:11 AM
Thanks a lot, second link was a really helpful. You have to use Auto NAT rules, but can't use the same source objects, so you have to create 2 different network object with the same address space inside. It works!
02-15-2021 09:55 AM
yes, that is the trick, nice to know all working as expected.
