Cisco IOS XR EEM
mkhalil10
Hi , I have Cisco ASR9k running with NAT44 service
I have some numbers to monitor that will be extracted using show | include
I want to write an EEM script that will take an action if this value exceeds a certain value
As well , can I draw these value using show with include option ?
46 Replies 46
Nothing would appear unless you're on the console or monitoring the current VTY line.  The results are printed via syslog.  If you want the results to appear on the same terminal outside of syslog, change the "action_syslog msg" command to "puts" and reregister the policy.
Hi Joseph
I have tried to modify the script , but it did not appear until I have added the puts "$_cli_result" line again , please find the complete script
::cisco::eem::event_register_none sync yes
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_write $cli1(fd) "run attach 0/1/CPU0"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_read_pattern $cli1(fd) "#"} _cli_result] {
if [catch {cli_write $cli1(fd) "show_nat44_stats"} _cli_result] {
set output $_cli_result
if [catch {cli_exec $cli1(fd) "exit"} _cli_result] {
foreach line [split $output "\n"] {
    set line [string trim $line]
    regsub -all {\s+} " " $line line
    if { [regexp {^([0-9]+) ([0-9]+)\([0-9]+%\) ([0-9]+)} $line -> core sessions users] } {
        puts "Core: $core, Sessions: $sessions, Users: $users"    }
puts "$_cli_result"
# Close open cli before exit.
catch {cli_close $cli1(fd) $cli1(tty_id)} result
As well , the issue am facing is that the output is missing and not complete , please check below
RP/0/RSP0/CPU0:UM-HQ1-CGN-3G-NAT1#event manager run CGN1.tcl
Wed Apr 22 09:47:52.397 AST
  55269(42.17%)
            3              672614(23.4%)             55571(42.40%)
            4              232347(8.1%)              11434(8.72%)
            5              228224(7.9%)              11400(8.70%)
            6              231314(8.0%)              11359(8.67%)
            7              221876(7.7%)              11425(8.72%)
                 Total Sessions: 3581296                 Total users: 267455
Main DB size is 2875008 and User DB size is 131072
Thanks a lot for your help
BR,
Mohammad
As well , I have the below script
::cisco::eem::event_register_timer cron cron_entry "*/1 * * * *"
} else {
if [catch {cli_exec $cli1(fd) "show ipv4 interface brief | exclude unassigned"} _cli_result] {
puts "$_cli_result"
Which is working , but when I change the show command to the below , it's not working
show cgn nat44 nat1 statistics | include "sessions|subscribers"
Can I append a file on a TFTP server (windows machine)?
Can I draw this ?
BR,
Mohammad
Your command has embedded quotes.  Assuming it works when you type it manually, then this should work in Tcl:
if { [catch {cli_exec $cli1(fd) {show cgn nat44 nat1 statistics | include "sessions|subscribers"}} _cli_result] } {
Yes, you can save this to a TFTP server.  Just execute the commands you'd have to execute manually as cli_exec within Tcl (assuming they are not interactive).  If the commands are interactive, then you'll have to follow the example in the other Tcl script to use cli_write and cli_read_pattern to respond to the prompts.
if [catch {cli_exec $cli1(fd) "show ipv4 interface brief | exclude unassigned"} _cli_result] { - See more at: https://supportforums.cisco.com/discussion/12413351/cisco-ios-xr-eem#comment-10448341
Interesting.  Seems the output isn't being saved where it should.  Try adding:
append output $_cli_result
Right before the "foreach" line.  See if that helps.
Hi Joseph
I tried to add the append output $_cli_result but the same output (the missing output) appeared again
The script is fine , I just need to resolve this issue
BR,
Mohammad
What does your current script look like?
} else {
puts "$_cli_result"
I see the problem.  Change the regexp line to:
if { [regexp {^([0-9]+) ([0-9]+)\([0-9.]+%\) ([0-9]+)} $line -> core sessions users] } {
Then if you want to see the full matched output, change your last puts to:
puts $output
The same
RP/0/RSP0/CPU0:CGN-3G-NAT1#event manager run CGN1.tcl
Mon May 11 10:39:58.201 AST
#  57521(43.89%)
            3              769793(26.8%)             57527(43.89%)
            4              246830(8.6%)              11543(8.81%)
            5              259836(9.0%)              11620(8.87%)
            6              246769(8.6%)              11585(8.84%)
            7              261787(9.1%)              11650(8.89%)
                 Total Sessions: 4105605                 Total users: 276219
Terminating attach to node 0/1/CPU0..
Chane the regsub line to:
regsub -all {\s+} $line " " line
And it looks like you didn't change the last puts so that it prints all output?
Hi Joseph and sorry for keep bothering
The output differs but still missing
Tue May 12 10:25:53.837 AST
Core: 3, Sessions: 763202, Users: 57544
Core: 4, Sessions: 240879, Users: 11622
Core: 5, Sessions: 254223, Users: 11545
Core: 6, Sessions: 243926, Users: 11479
Core: 7, Sessions: 237100, Users: 11545
#  57455(43.83%)
            3              763202(26.5%)             57544(43.90%)
            4              240879(8.4%)              11622(8.87%)
            5              254223(8.8%)              11545(8.81%)
            6              243926(8.5%)              11479(8.76%)
            7              237100(8.2%)              11545(8.81%)
                 Total Sessions: 4020292                 Total users: 276022
The complete script now looks like the below
} else {
puts $output
You may need to move the "set output" command right after you run the show_nat44_stats command.  Then change the existing "set output" command to:
Hi Joseph
Still the same output
I meant for there also to be an append output $_cli_result after the cli_read_pattern call.  Add that, then change the cli_read_pattern line to:
if [cli_read_pattern $cli1(fd) {#\s}} _cli_result] {
