Cisco IOS XR EEM
mkhalil10
Hi , I have Cisco ASR9k running with NAT44 service
I have some numbers to monitor that will be extracted using show | include
I want to write an EEM script that will take an action if this value exceeds a certain value
As well , can I draw these value using show with include option ?
46 Replies 46
Hi Joesph
Please check below
::cisco::eem::event_register_none sync yes
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_write $cli1(fd) "run attach 0/1/CPU0"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_read_pattern $cli1(fd) "#"} _cli_result] {
if [catch {cli_write $cli1(fd) "show_nat44_stats"} _cli_result] {
append output $_cli_result
if [cli_read_pattern $cli1(fd) {#\s}} _cli_result]
if [catch {cli_exec $cli1(fd) "exit"} _cli_result] {
foreach line [split $output "\n"] {
    set line [string trim $line]
    regsub -all {\s+} $line " " line
    if { [regexp {^([0-9]+) ([0-9]+)\([0-9.]+%\) ([0-9]+)} $line -> core sessions users] } {
        puts "Core: $core, Sessions: $sessions, Users: $users"    }
append $output
# Close open cli before exit.
catch {cli_close $cli1(fd) $cli1(tty_id)} result
Is this the right format ?
Thank in advance
This looks right (assuming there is in fact a space after the '#' prompt).  You may have to play with that regular expression so that it matches the prompt without matching the other '#' in the command output.
