Cisco LI MIB
Kerem Gursu
I try to implement Cisco LI MIB on a 7406 VXR chasis. I issue the command from the mediation device
merlyn@revan ~ $ snmpget -v3 -u liuser -a MD5 -A password -l authNoPriv 192.168.111.1 cTap2StreamInterceptEnable
within the documentarion cTap2StreamInterceptEnable command is supposed to be enabled . when I use the command above with snmpget , the following error message is displayed .
cTap2StreamInterceptEnable: Unknown Object Identifier (Sub-id not found: (top) -> cTap2StreamInterceptEnable)
Is the command that I try to use correct ?
Thanks in advance ,
http://www.cisco.com/en/US/docs/ios/sec_user_services/configuration/guide/sec_lawful_intercept.html#wp1077988
Dan Frey
Appears you do not have the CISCO-TAP2-MIB loaded on the NMS.   You can either load this mib along with all the dependancies, or call the oid out by numeric oid.
If you do not want to load the mib try:
snmpwalk -v3 -u liuser -a MD5 -A password -l authNoPriv 192.168.111.1 1.3.6.1.4.1.9.9.399.1.2.1.1.3
