Cisco Network Assistant 6.3 (4) java.lang.NullPointerException
xiongguoy
Community Member
Cisco WS-C2960X-24PSQ-L 15.2(7)E3
When trying to configure port settings:
ERROR: C2960X the CommandSet feature feature failed for this device
Application log and screen shot attached.
6 Replies 6
pieterh
org.apache.commons.httpclient.NoHttpResponseException: The server 10.1.1.3 failed to respond
=> did you enable http/https access to the device?
xiongguoy
Community Member
It happens regardless whether I connect via http or https.
Everything else is ok, only when try to configure port settings.
you did not understand my question: => did you enable http/https access to the device?
suggests 10.1.1.3 is not reachable for http(s) requests!
so the question is does the switch-config contains HTTP/HTTPS enable command? (not within CNA)
if in doubt attach the running-config of the switch to this post, the i can check.
If http(s) isn't running, wouldn't I won't be able to connect at all?
I can connect and view/configure everything else except ports.
stefanoV
Community Member
 hi, I have the same problem, and yes, http/https is enable. Thanks for helping
the nullpointer exception is caused by Java, not much you can do about it. Which Java version are you running ? You can try and upgrade your Java, check the link below:
https://linuxhint.com/check-update-java-version/
