Cisco Network Assistant
Hello Team,
Im using Cisco Network Assistant version 6.3.2. I now that this product is not developed anymore but maybe somebody can help me. Generally I add my netwrok and I would like to select only my switches. So I go to topology options -> Show neighboes -> disable everythin (I left only Other neighbors to see switch connection) but still I see my AP (AIR-CAP). Is there any option that I can delate AP from the view, becasue when I disable other neighbors I can see only switches but without connections. I tried many versions of CNA (also newer 6.3.4 and many olders) but different versions -different bugs.
Or maybe there is simillar application to see the view of the network.
Thank you for help.
Bartek
0 Replies 0
