Cisco Network Assitant
bhhouston
I have a number of Catalyst 2950 switches that I manage with the Cisco Network Assistant (v 2.0). I can see all the switches inside the LAN but can't see any switches inside my DMZ or my point of entry switch outside the firewall.
Is there a way to configure my firewall so that I can see these switches with the Network Assistant?
Thanks, Ben
nhabib
Level 9
Level 9
CNA uses http to connect to the switches
You will need to make sure that none of the http traffic is blocked at the firewall
For additional information regarding firewall, you might want to go to the Security part of NetPro
necesito el software cisco network assitant pero ya no esta disponible me pueden ayudar por favor
Hola,
sabes que el software es antiguo y obsoleto...
