Cisco PI 2.0 Configuration Archive fails Nexus 5000
m.o.andersson_2
we recently upgraded Cisco PI from 1.3 to 2.0 and i thought this problem would be solved but it did not. I have added two Nexus 5548 switches that i can monitor and configure through Cisco Prime but im not able to read the running och startup config to the Configuration Archive. When i run the job i get the following error:
"fig from device: java.net.SocketTimeoutException: Read timed out"
Current NXOS: 5.2(1)N1(2a)
Before i proceed troubleshooting i just would like an answer if it should be possible to archive configs from Nexus to Cisco Prime Infrastructure?
Cheers! // Mattias Andersson
2 Accepted Solutions
Marvin Rhoads
Yes, I am doing it successfully on a couple of Prime 2.0 installations. My instances included a bit later NX-OS - 5548UP and 5596UP running 5.2(1)N1(4) and 6.0(2)N2(1b).
Thanks for the quick reply! Well, i did some more troubleshooting and i noticed that through Ethanalyzer and inspected the telnet packets that Prime tries to set the terminal lenght and width before it shows the running-config but it fails as it is in the default role of priv-0, and therefore gets % Permission denied. So, it times out after 2,5 min.
I added these two lines and worked like a charm!
role name priv-0
  rule 12 permit command terminal length *
  rule 11 permit command terminal width *
Marvin Rhoads
role name priv-0
That's good info to know. My cases all used a username with level 15 network-admin privilege level.
Nice sleuthing. +5!
