Cisco PI 3.0.2 (now 3.1.6) Custom Syslog Event doesn't appear!
Daniel.Karl
Hi Guys,
I got a problem with my PI.
I created a Custom Syslog Event but it doesn't appear.
When I create a new rule, it is added successfully but is also not shown.
The rule still exists, when I try to add a rule which is already created, it shows:
I can't see the created rules.
Is this a bug? What I have to do, to see the rules again?
Daniel
7 Replies 7
Daniel.Karl
We upgraded our PI to 3.1.4 but the problem is still there.
Anyone has the same problem?
Could be the bug CSCva32373:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva32358/?referring_site=bugquickviewclick
Did you create a custom syslog event with a special character?
hth
Andy
Hi Andy,
first, thanks for your answer.
I didn't use special charasters, as you can see in my attached screenshot.
Further the automatically created event appears, but not the rule.
We installed the 3.1.6 Patch and the problem is still present...
The message type is incorrect. It should be something like: (Just an example, so test it with the message type that you want in your live environment.)
%SW_MATM-4-MACFLAP_NOTIF
The screenshot above with "test" is just an example to show you, there is no entry although the creation is marked as successful.
I already did this with "user-login" and I can see the created events but not the entry in the list above.
Therefore i can not delete any custom syslog event pattern.
Daniel.Karl
Update: This Issue has been fixed in Prime 3.2
