Cisco Prime 1.3 TFTP/FTP servers
jino_jacob
We recently upgraded from WCS to Prime infrastructure and i'm trying to figure out how to browse the configuration backup files that Prime pulls from the controllers.
I have enabled the TFTP/FTP servers under server settings and set the Controller configuration backup to use 'Default Server'
--> Can someone please tell me how i could scoop the config backup files out of Prime Infrastructure default TFTP server?
--> What would be the FTP username/Password for the default server or how do i set one?
-- >Also, backup task is not successfuly for some devices and gives a message -
"Failed for some devices. Please search for "Controller Configuration Backup" in NCS logs for more details""
I downloaded the log file from Administration - Logging. Not sure where i should be looking since there is ton of files in the zip package?
Thanks in advance for any help you could provide.
Jino
Rob Johnson
1.  If you're running PI 1.2 or 1.3::: enable the root password by typing root_enable from the CLI and entering a root passowrd.  Once the password has been setup and entered, type root and press return.  This will take you to the linux OS shell.  From there, cd /localdisk/tftp and from there you will see the files using the ls command.
2. The username and password you will use to ftp to/from NCS/PI is ftp-user ::: to set the password go to the CLI and type ncs password ftpuser ftp-user password
from the log files there's an inventory.log and i think the other is ifm_inventory
pull the log files over to a linux or unix box then grep for the IP address of the device giving you problems...
Hope this helps
Rob Johnson
Hope this helps
