12-07-2014 07:33 AM
Hello All,
I have around 80 Cisco 3850 switches at a customer network and they are using prime infrastructure 2.1.2 to manage these devices. Most of the features are working fine except that the prime does not show the wired clients connected to the switches. The wireless clients are shown properly but not the wired clients. Their core switches are nexus 7k. The SNMP configuration on the switches is as follows.
snmp-server group xxxx v3 priv write xxxx-VIEW-WR
snmp-server view xxx-VIEW-WR mib-2 included
snmp-server trap-source Vlan100
snmp-server host x.x.x.x version 3 priv testuser
Please help me to resolve this issue.
Shabeeb
12-07-2014 08:56 AM
I believe you need to use the netadmin SNMP RO credential set to properly collect end host data on the Nexus platforms.
12-07-2014 12:18 PM
I managed to get the end hosts connected in 3850 switches with the use of snmp context command. But now the issue is that prime is showing only the mac address of the device , not the IP address.
Is there anyway to resolve this issue?
12-07-2014 01:11 PM
Dis you try using the netadmin SNMP user credential on the Nexus?
12-07-2014 08:09 PM
No.. " net admin" is a user role in the nexus right??.. I have to assign that user role to the snmp user I guess..
12-07-2014 08:20 PM
I assigned the user to the system defined role "vdc-admin". But still the same
12-08-2014 06:12 AM
Do you have multiple VDCs?
If so, each needs to be managed directly (i.e., essentially as separate devices) by Prime Infrastructure.
07-11-2017 07:58 AM
I have the same problem. Did you get any solutions for it?
