Cisco Prime 2.1 sh commands
RICARDO SANCHEZ
Hello
It is possible to take some show commands of a group in CiscoPrime 2.1 and then get this files?
Thanks for your help
Sure.
In Lifecycle mode you design a template (Design, Feature Design, CLI Templates). See the existing pre-configured templates for examples. Then create one with the commands you want and give it a useful name. (You can adapt the "Configure SNMP" template for example.)
The deploy it: Deploy, Configuration Tasks:
 Templates > CLI Templates > System Templates - CLI > Configure SNMP
Choose your device group, site group etc. as targets and then deploy.
Marvin Rhoads
I don't think so. This is a feature that was available in Prime LMS that has not yet been ported into PI.
Thanks Marvin for your response.
And what about to make some changes in configuration  of a group, for example
  • conf t
  • no snmp-server community X
  • snmp-server community C
It is possible to do whatever templet I want for a group in prime infraestructure 2.1?
Sure.
Thanks Marvin
I did that and Its works
regards
