01-08-2016 11:55 PM
Hai i was trying to integrate NAM3 on 6513 with our prime 2.2.0 server,following issues noticed
1. I am not login to NAM,i correctly configured,its asking privilege 15 access required,any ssh patch need to be installed,on NAM i didn't install any patch
2.Is there is any documentation regarding prime for making polling of interface data fro NAM
thank you
Solved! Go to Solution.
01-09-2016 08:07 PM
Hi Vijay,
check the below links ::
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/setup_monitor.html#86952
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/setup_monitor.html#41501
Thanks -
Afroz
***Ratings Encourages Contributors ****
01-09-2016 08:07 PM
Hi Vijay,
Thanks -
Afroz
