Cisco Prime 2.2 Database Questions
Irvin Theunis
Hello
Can you copy Prime 2.2 database to an external harddrive and if so how can I do that?
Does the database reside in the optvol disk?
Does Cisco Prime 2.2 allow interaction with other servers so that information can be pulled from the Prime 2.2 database?
Could you please let me know.
ngoldwat
Level 4
Level 4
The DB does reside within the /opt directory.
Prime has an API that allows for other processes to interact. Here is a link to the documentation:
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/api_reference/guide/cpi_apiref22.zip
