Cisco Prime 2.2
reilly.john
I am soon to be updating my Cisco WCS server to Cisco Prime 2.2
Presently the WCS is on a UCS 200 VMware 4.5 which will be decommissioned.
I can get the VMware specs on the new server and the hardware device specs.
What I need clarification on, is there a software version to load on my own physical server other than on VMware?
What I am assuming is that the hardware device specs are for the hardware device ordered direct from Cisco.
Thanks for your help
John
AFROJ AHMAD
Hi John,
Yes you are right.
Required Hardware
You need the following equipment to install a Cisco Prime Infrastructure appliance in an Electronics Industries Alliance (EIA) rack:
  • A Cisco Prime Infrastructure appliance
  • Network cables
  • One rack unit (RU) free space in an EIA-standard rack
  • Rack mounting kit (included with the Cisco Prime Infrastructure appliance shipment)
  • A serial console cable
check  the below link::
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/hardware_install/guide/Cisco_PI_Hardware_Appliance_Installation_Guide/cpi_higmain.html#pgfId-1057848
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi John,
Yes you are right.
Required Hardware
  • Network cables
Thanks-
Afroz
Thanks for the information.
