01-24-2023 07:45 PM - edited 01-24-2023 09:30 PM
I updated to CPI 3.10.2 from 3.9 and after that noticed that in congiguration archive all ot them is show with error encoding type, I can't see what there.. such as
01-24-2023 11:17 PM
- Try using another browser ,
M.
01-24-2023 11:35 PM
I tried it's the same, config this is collected again show normally, it's problem only with previous versions
01-25-2023 12:23 AM
- Not sure if this then is an 'effective' problem, since this Prime version is new you may want to engage TAC and ask for clarification ,
M.
01-25-2023 01:40 AM
it looks like the configs are masked, which usually is something that happens when you export the files (there is, as far as I recall there is an option to sanitize/unsanitize the files). Can you export the files successfully (and read the content) ?
01-25-2023 02:00 AM
No it isn't masked, because before it was normal. After download I get the same result
sanitize - feature which hides password/secret etc not all of them
01-25-2023 02:02 AM
No it isn't masked, because before it was normal (sanitize - feature which hides password/secret etc not all of them). After download I get the same result
01-25-2023 02:09 AM
ok. So the entire content is scrambled. What if you do an on-demand manual backup ? Is the 'new' content visible ?
01-25-2023 02:56 AM
yes, if I push button "Schedule Archive Collection" now. CPI downloads config and after I can see this new config
