Cisco Prime 3.3 CLI - Banner Configuration
syyang28108
Hello all,
There has to be an easier way to add a banner to the Prime CLI pre-login screen but I can't seem to figure out a way to do it. I've tried to scp/sftp/ftp/tftp/nfs a banner.txt file i created from a directory on my fileserver but I get an error: transfer failed. It's asking for a username and password for which i have no clue when i used some of the protocols. What am i doing wrong?
I've read some articles but nothing specific... Your help is very much appreciate it.
balaji.bandi
If it asking username and password (means your required authneticaiton)
best way to setup a TFTP and copy banner.txt in the root folder of TFTP and use it, make sure TFTP IP reachable to Prime
follow bannerl configuraiton :
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-3/user/guide/bk_CiscoPrimeInfrastructure_3_3_0_UserGuide/bk_CiscoPrimeInfrastructure_3_3_0_UserGuide_chapter_011000.html
BB
yajimene
When adding a banner to Prime Infrastructure, it will follow this syntax:
PI/admin# banner install pre-login <filename> repository <repoName>
So you need to create first a repository pointing to your ftp server, make sure you add the ftp user and password:
conf t
url ftp://X.X.X.X
user <username> password plain <password>
So let's say I have my banner.txt stored on an ftp server IP: 10.2.2.2, where I configured an ftp user/password: ftp-user/cisco123
conf t
repository FTP
url ftp://10.2.2.2
user ftp-user password plain cisco123
exit
banner install pre-login banner.txt repository FTP
That worked for me.
- Yaros
