Cisco Prime 3.8 + Netflow
Jay_Work
We've added netflow commands to our switch and added the device data sources in Prime 3.8. They are enabled, however i'm unable to see any traffic under dashboard > performance > application. Sorry but i'm new to Netflow (Not Prime) so if anyone can advise on tips/advice of how I can get to see application flow in Prime that would be helpful?
Thanks in advance.
marce1000
  - Do you have Assurance  license(s) in order to be able to use Netflow ?
 M.
Yes we have assurance licenses and I can see that Prime is using one.
  - Have a sanity check of the configured netflow(s) on the devices by for instance using a free Netflow-analyzer and verify if Netflow data are being received :
    (e.g.) : https://www.paessler.com/netflow_monitoring?gclid=CjwKCAiAz4b_BRBbEiwA5XlVVkw8nZ8I9Iyd7SA_c3_yF1QmDvjOBu_lBBLKhy9JPDaBsdqJYNd_HBoChasQAvD_BwE
 Further more verify device compatibility matrix -> pay attention to required software versions (tab 2  en tab 3) , for the devices configured in Prime.
 https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-8/supported/devices/PI38-Supported-Device-List.xlsx
  M.
