Cisco Prime Infrastructure 1.2 OVA not found
Aaziz AMHAOUCH
Hi all,
I want to download Cisco Prime Infrastructure 1.2 OVA but I can't find it, there is just  "Cisco Prime Infrastructure 1.2 Plug and Play for Virtual Appliance " . Is this the right OVA ?
Thanks for your help
BR
Aaziz
AFROJ AHMAD
Hi Aaziz,
Unfortunately this download of this file is not available anymore on cisco.com site.
As an alternative, you can download PI 1.3 OVA, where you can find the same features and
interface:
http://software.cisco.com/download/release.html?mdfid=284652876&softwareid=284272932&relea
se=1.3&relind=AVAILABLE&rellifecycle=&reltype=all
Note:  you can use the same license of PI 1.2 on PI 1.3
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Aaziz,
interface:
Thanks-
Afroz
Hi Afroz,
Thank you for your reply, It helps me !
BR,
Aaziz
Hi Afroz,
is the license of PI 1.2 on PI 1.4 ok?
tks a lot.
