Cisco Prime Infrastructure 1.3 / Device Work Center/ delete Site Group
Mike Hinnen
I've configured two dynamic Groups, Access Switch and N44.
How can I delete this two wrong groups?
7 Replies 7
Nael Mohammad
Level 5
Level 5
The site group can be removed from the lifecycle them under "Operate --> Maps" and then on the left hand side, you will see the Map Tree View.  And on the page you will see the listing of all the corresponding site maps. You will need to select the check box and from the select command option in the upper right hand corner, choose delete.
Thanks for you answer.
But this is not the solution.
I have two site groups, one with the static groups witch I can found also under Operate --> Map and one with the dynamic groups witch are not visibal under Operate --> Map.
I would like to delet the dynamic Groups.
N44 and Access Switch.
I remember reading that this must be done from the CLI. I am sorry, but I do not have a link to the document I read it in.
Did you ever figure this one out? They are easy enough to create a PITA to remove.
This bug makes it very difficult to learn the product and play around with configurations and then delete the changes. This bug is not the only present in the software. The same thing occurs when you create port groupings as well. You are unable to delete them.
Not real sure I like when they say, they aren't sure why this occurs.
tronchetti
Mike,
I was able to remove a user defined group in PI 1.3 in Operate>Device Work Center.  Hover over the 360 icon next to your sub-group, a pop-up will appear with an option to delete.  See the screenshot.
