Cisco Prime Infrastructure 2 - compliance,EOL/EOS
mvandenbent
Since this week I am evaluating Cisco Prime Infrastructure 2 and I have a few questions:
- Some configuration rules are mandatory. Is it possible to run custom compliance reports with a custom baseline template? Where/how can I make a baseline template?
- Where can I find EOL/EOS information for our devices?
Thanks in advance,
Marnix
AFROJ AHMAD
Hi Marnix,
unfortunately , you can't create custome reports in PI yet , planned for future release.
Baseline Templates are also not supported yet.
check the below link for feature support in PI:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729089.html
You can use cisco. com and google to know the EOS/EOL of your device.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Marnix,
Thanks-
Afroz
Afroz,
Thank you for your reply. We would like, if it is possible, to proactively informed when devices become EOL/EOS soon in the software. Searching EOL/EOS dates by hand is impossible when monitoring 1500+ active devices.
My questions are answered, thank you!
Marnix
For EoS/EoL you can load your devices into the free Cisco Active Advisor tool.
http://www.cisco.com/en/US/products/ps13221/index.html
Once you get them all loaded, you will get regular advisories on EoS/EoL and PSIRTs.
You can also use Prime LMS (separate server, license included with PI) which does generate those reports.
ShaunGreen
Hi There,
I'm not sure if we are talking about the same thing, but we are running Prime Infrastructure 2.0.
You have to enable compliance from the settings (restart) and if you look under Report / Report Launch Pad, in the menu on the left is Device, click on there and you will see EOX ...... I've only had a quick look at the reports, but looks to work.
Simon
