Cisco Prime Infrastructure EVAL HELP!
Chris Alvarado
Just installed the evaluation copy of Cisco Prime Infrastructure 3.2. I went through the setup prompts and I can ping the server from my network and from a network stand point it seems good. However I can not web into the system to actually trial this. The troubleshooting guide says to run command 'ncs status' to check the status of the server. However I get the following error.
sh: /opt/CSCOlumos/bin/wcsadmin.sh: No such file or directory cisco_prime_sreen_shot.jpg
Please advise on how I can get this running.
Mark Elsen
 - Can only assume that the install got corrupted for some reason; make sure that you are using a supported/compatible  platform (hypervisor/version) (e.g.). And take into account the needed systen resources required too.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
That's what I would say, too. Are you sure you installed with enough disk space?
I meet all the hardware specs as defined by the recommended Express version. Should I do a reinstall?
Yes, please do a reinstall.
