Cisco Prime Infrastructure - Import Maps Archive
calfik885
Hello Folks,
I am going to export 1 office location from one PI and wanna import map archive and bulk APs for this office in to the other PI. Can anybody advise if I can import a Maps for specific office location (1 site) only? I do not wanna overwrite all Hierarchy in our PI.
pieterh
It has been a long time since I've done that and have no active Prime environment to check
But as I recall YES you can do that !
both on map export and on map import you can select what Items the action is performed on.
