Cisco Prime INfrastructure partial Authentication failure Error
nabeelcse07
I am currently working on Prime Infrastructure and mistakenly I removed the devices that were added previously from it. Now When I add the devices one by one it gives error "Partial Authentication Failure" and it gives alarm about NCS backup repository.
Can anyone help in this? how to resolve this.
NA
If you hover your mouse next to the "Partial authentication error", it will tell you the reason why it went to that state.
You would need to tell me what the error about NCS repository is. Is the HDD getting full ? Try doing a NCS Cleanup or deleting your older backups from that folder. Always, it is a good idea to have the NCS repository point to a FTP Server and NOT take the backups locally on the server.
Yes It says not enough space.
