Cisco Prime LMS 4.2 ExceededMaximumUptime
Rodrigo Bezerra
Please I need help. I'm monitoring some switch 3750x.  The  event ExceededMaximumUptime alarm  for uplink interface.
Could someone tell me what it really means this alarm?
In the cisco website (link below) tells me that is a backup interface. But backup interface for 3750?
http://www.cisco.com/en/US/customer/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/lms_monitor/mnt-setup.html#wp1358336
Backup Interface Support
The Backup Interface Support threshold configures an interface as a backup. When an interface is identified as a backup:
The InterfaceOperationallyDown event is not generated if the interface is down.
The ExceededMaximumUptime event is generated if the interface stays up too long.
Vinod Arya
Following is the description :
Description: A backup or dial-on-demand port or interface has been in the Up state for a long time.
Trigger: Exceeded Maximum uptime threshold.
Severity: Critical.
Device Type: All (except Network Management).
Event Code: 1002.
Component Codes:
Port: 1028.
Interface: 1027.
On any other Component: 1026.
You can unmanage the interface you have an issue with, or you can set the alarm threshold from value to 0 to stop receiving alerts.
The maximum length of time, in seconds, that the interface may be up before the ExceededMaximumUptime event is generated. If the value of this parameter is 0, the ExceededMaximumUptime event is disabled.
You can set threshold as following to 0 or increase it:
Minimum and Maximum Threshold Parameter Values and Related Events
Threshold Category
Applicable Threshold Parameters (with unit of measure)
Values
Events Generated after Value Passes Threshold
Min
Max
Default
Maximum uptime (seconds)
Dial-on-Demand
7200
For changing check Editing Thresholds.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
That would be a problem ExceededMaximumUptime me know what detail problem? Sorry but i still not able to understand? Because category backup interface support?
Sorry did not understand
thanks for help
Dial on demand interfaces are used with Dial on Demand Routing (DDR) is a routing technique where a network connection to a remote site is established only when needed.
These interfaces are not up regularly and when activated, LMS keeps a track and when counter reaches threshold limit as per LMS, it sends ExceededMaximumUptime alert for that interface.
So if the interface in question is a Dial-on-demand interface and is up. The maximum length of time, in seconds, that the interface may be up before the ExceededMaximumUptime event is generated.
-Thanks
