Cisco Prime- Netflow Export Issue
Prasan Venky
Level 3
Level 3
Dear All,
We are observing high bandwidth being utliized between ASR1004 and Cisco Prime 2.1 after enabling "ip netflow exporter". Is there any way to mitigate it..?
Marvin Rhoads
Yes - use sampled Netflow which statistically samples the flows instead of trying to send every single one back to Prime Infrastructure.
The IOS-XE configuration guide section on Netflow describes how to set it up.
