Cisco Prime Network 4.1 Licensing
ar
Hi.
I will be supporting Cisco Prime Network 4.1 and will need to install RTMs.
During obtaining license, does the PAK includes the Prime version so I get exact match RTM license version?
If my RTMs are version 4.2.2, can I install it in Prime gateway 4.1?
How do I install the license? Is it the same as version 3.8 documentation?
I cant find good licensing docs for 4.1.
thanks in advance
kayukovvalera
Hi, RTM mean Right to Manage, this is paper type license. You don't need to install it.
how do we apply if say customer bought latest license while they are using outdated Prime version?
