Cisco Prime NMSP enable
skelley5000
I am adding my Cisco 3750's into prime and I would like to enable NMSP fro each switch using prime.So far I have only found the way to do this is by editing each switch once Prime has synchronizing with the switch. Is there away to do this in bulk? I have hundreds of these switches and it would take me for ever to do each...
Marvin Rhoads
What you're asking about can usually be handled via a template. You can use either one of the pre-configured ones (adapting it if it doesn't quite fit your need) or create a cli template from scratch. Here is a link to the documentation section showing how that's done.
Once you have a template, you simply deploy it to your switches. You can choose all of a certain model or place them ones you want into a group and deploy the template to the entire group.
If you'd like to see it in action and get some more information, please have a look at this YouTube video that Eric and Tomer from the business unit demonstrate this feature.
