Cisco prime SCP for update
I'm trying to SCP the cisco prime update tar.gz file to the prime server but when I use the scpuser it gives me an authentication error.
I got the UN/PW from getSCPCredentials.sh
balaji.bandi
That should work as expected - if you have username and password - when you using sh file to generate.
Other options you can use :
If this appliance you can use USB also.
or you can use repo also :
https://mrncciew.com/2014/01/12/upgrade-prime-using-cli/
BB
Do I need to scp to a specific directory?  I'm thinking maybe that is the problem.
You can choose the right folder to copy, but you are getting authentication error as you mentioned in the OP so i suggested other option.
BB
