cisco prime
CSCO12130174
hello,
im having some problem with my PI because every time i tried to log out of PI to activate my licenses it keeps prompting "Cannot create a session after the response has been committed" whats the problem? could it be java?
13 Replies 13
AFROJ AHMAD
seems to be this BUG:
"{"message":"Cannot create a session after the response has been c.... CSCug37893
Workaround : Restart the PI
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Afra,
i've restarted the PI but its still not working. what could be the other solution? im stuck :S
Zhafri
Hi Zhafri,
what is the version of PI ?
share the output of " show ncs status" or show status application NCS"
If possible reboot the sever and check the issue
Thanks-
Afroz
Hello Afra,
The version of the PI is 1.2.1.012 and im running on a virtual platform (UCS) back then when i try to log out it was successful but now the error pops out. where could i gain the output?
Zhafri
from the PI cli  do the below:
ncs stop
then
ncs start
and then check the error message
Thanks-
see the attachment below, this is what i get after i did the ncs stop and ncs start.
regardss
Zhafri
here it is.
process are running fine..
can you try to remove and re-add the license and see how it works
Thanks-
Afroz
its still the same error afra :/
Zhafri
hello afra
do you have any suggestion or solution on the error?
Zhafri
Hi Zhafri,
most of the customer issue got fixed after the restart of the service..not sure why it is not fixing here..
you can open a TAC case for further assistance.
****If some one had a different  view or suggestion ,please share with us***
Thanks-
Hi Zhafri,
I would suggest you to upgrade the PI to 2.0 which have the fix of this issue.
You will not be required to have a new license if you plan the in-line upgarde (mean on the same server) but if you plan to installaed on a new machine then you will need to conatct the License team to Re-Host the license
Thanks-
Afroz
