How to use telnet to enable SNMP in a router ?
DALHI_Ahmed
Is it possible to enable the snmp in a router via telnet with the wan address(I have the routers' passwords) ?
If yes, how
Router 1 : Cisco 871 w
Router 2 : Sagem – F@st 3304 v2
thank you
Waiting...
5 Replies 5
Michel Hegeraat
Level 7
Level 7
in the cisco871 just type:
conf t
snmp-server community RO
ctrl-z
For the sagem, I know you can turn it on but I forgot how I did that.
I got my info from this site: http://www.ripperjack.info/b-boxandco/spip.php?rubrique1
Cheers,
Michel
Hi Michel,
I think you are talking about, enable snmp manually,
What I am supposed to do is, enable snmp in some routers(that I know their WAN ip addresses & their passwords) using TELNET.
Thank you,
Waiting...
Yeah, enable SNMP manually, using TELNET.
And you can use the wan IP address to TELNET to the device unless an ACL on the device prevents you to do this.
I guess I don't uderstand what you want, but I may not be the only one.
Cheers,
Michel
Command Prompt:
telnet @router
login: root
Password: ********
[root @ home]$
What I should do next  ?
That prompt doesn't look like a cisco 871. The example I gave was for a cisco.
As said I forgot, for the sagem. I think I got my info from this site: http://www.ripperjack.info/b-boxandco/spip.php?rubrique1
But I'm now wondering if I didn't enable SNMP on my previous router, a netopia.
Cheers,
Michel
