03-26-2022 06:58 PM - edited 03-26-2022 07:00 PM
Solved! Go to Solution.
03-27-2022 09:13 AM
your cells are formatted as numbers, I think they have to be text. I opened your file in LibreOffice and saved the cells as text (file attached) not sure if that works, if not, try and format the cells as text yourself, with the software (Excel I guess) you are using...
03-26-2022 07:44 PM
how about just 10 Lines and try to import? is that works ?
03-27-2022 09:13 AM
05-19-2022 05:52 PM
@Georg Pauwen Thanks for the information
