CISCO SG200-26 Switch
warrenmwiche
hey, i need help with port security. i have an SG200-26 switch it has port security features but i cannot find the err discovery option when i go to port management.
5 Replies 5
On my port management there is just link aggregation and green ethernet options. can not see Err recovery option.
balaji.bandi
You mean error recovery option ? if so
check in port management option you see there ?
On the bottom you can see reason for the suspension.
BB
may be because of the basic switch may not be able to do the task
May be i am looking 250 onwards have that option as per emulator.
BB
port-security is configured under Security > Port Security,
IF error-recovery is available on this switch  it should be here, not port-management
but the manual in this link does not mention this option So I guess you can only manually recover from violations
