Cisco SG300 VLANS Really need help.
MDSCiscoTech
I cannot make this work no matter what network diagramI do. This picture shows my intended goal. but I cannot ping between different devices.
If I'm on VLAN 130 (192.168.130.77/24) with a pc plugged a port that is a member of VLAN130UP/VLAN132 ....
I cannot ping a pc or phone which is plugged into a similar port  which is on the VLAN 132 (192.168.132.55/24)
Hitesh Vinzoda
Level 4
Level 4
hi dude
it should be set to untagged when there is end device connected to it with respective VLAN set.
and PVID should be checked as well.
refer the below link
https://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=67844b99e2da4a7f88db0c588197487d_Creating_VLANs_on_Cisco_Managed_Switches.xml
Hitesh
