Cisco Switch 3560 Temperature
tiger_401
Dear All,
I have one of our switches showing Temp status as FAULTY, how you can help in this issue? Temp. About 127 C.
Please find attached pdf file.
Please help me in this regard.
Malik
2 Accepted Solutions
glen.grant
Where is the switch located , at that temperature it would be faulty or melted down . Check to see if the fans are running and whether the room where it is installed is adequately cooled.
sho env temp
or all
What does it say?
5 Replies 5
glen.grant
Thanks for your reply. The switch is located in server room. All other devices are working fine.
Is there any command through which we can check the temo using CLI. Please do reply.
Thanks & Regards,
Malik
sho env temp
or all
What does it say?
I will check it and will let you know.
Malik.
SW01# sh env temperature
TEMPERATURE is OK
SW01# sh env temperature status
Temperature Value: 42 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 51 Degree Celsius
Red Threshold : 61 Degree Celsius
