Cisco Switch 4507 series
kick534
HI team ,
i configured the user and password to login Cisco switch 4507 series
example below :
Core(config)#username cisco2030 password cisco2030
line con 0
privilege level 15
login local
stopbits 1
line vty 0 4
privilege level 15
login local
line vty 5 15
login
after configuring above i can telnet the switch with user and password.
but now the switch is showing error ( enable password not set ) i cannot login to switch.
please advise how can i set enable password.
balaji.bandi
same way how you configured username and password :
#configure terminal
(config)#enable password or secret  mypassword   << change the password from mypassword your desired.
also for reference basic setup :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/50sg/configuration/guide/Wrapper-46SG/supcfg.html#wp1020374
BB
hi balaji,
once i configured i cannot enter in to enable mode (no password set ), to configure enable password.
after user and password successfully configured i want to test working or not.
now how to bypass and enter the enable mode ( console and telnet both way i can enter into enable mode)
Julio Veas
You need to create the password for the remote access. You can do it this way:
R1 configure terminal
R1(config)#line vty 0 4
R1(config-line)#password mypassword
You can also do the same for the console port
R1config t
R1(config)#line con 0
Hope it helps.
