05-04-2011 02:43 PM
I added my UCM to CS and it shows up as expected. I ran User Tracking - Data Collection in CM but did not pick it up. I went into Admin - Data Collection - Device Management - Include... It did show up there so I manually added it to CM. Data Collection still does not pick it up. What else do I need to do? Would like to have IP Phones dialed in to LMS. Thanks for any help!
LMS 3.2, CM 5.2.1
Solved! Go to Solution.
05-06-2011 10:57 AM
What version of the CUCM are you running? Only the following is supported:
CUCM 6.1.1
CUCM 7.0.0
If any of the above, post the ani.log and ut.log with the hostname and IP of CUCM.
05-06-2011 10:57 AM
CUCM 6.1.1
CUCM 7.0.0
05-09-2011 10:46 AM
OK. Did not know that and had not seen the version requirement. I am running 4.3. Thanks
